05-03-2024 07:46 PM
Hello! I’ve been in Australia for 4 days now and have purchased a roaming pass which worked perfectly until today. Now when I am not connected to wifi I have an SOS symbol where the signal bar usually is and no data. I have restarted the phone a few times and toggled the airplane mode button to jump start roaming - it flashes up with 3G momentarily but then inevitably goes to SOS. This is in areas where I have had perfect signal previously so am really confused! Any ideas? Thanks
05-03-2024 08:02 PM
What is the result from performing a manual network search, and connecting to an alternative operator, manually?
07-03-2024 11:31 AM
have tried to switch to the alternative networks and none work 😞
07-03-2024 11:34 AM
To be clear, are you saying that a manual search finds alternative networks, but you are unable to connect to any of them?
Which operators are showing, and what happens when you manually select them?
07-03-2024 11:38 AM
Yes, alternative networks show up.
weve got Telstra Mobile (straight to SOS symbol) vodaphone AU (straight to SOS symbol) and YES OPTUS (which flashes 3G but doesn’t actually allow me to do data roaming)
07-03-2024 02:27 PM
Hi @evelyna1992,
Have you been able to test your phone in another location? This would help to rule out a local network issue.
07-03-2024 09:30 PM
Hiya! Yeah I’ve been all over Melbourne and it’s not working anywhere 😞
08-03-2024 07:37 AM
Thanks @evelyna1992
Are you able to try the SIM card in any other phone to see if you can connect to a network?
