Re: WIFI calling not working
peterg
My Wifi calling is not working - It is a BT router  and is operating normally. All I get is a message telling me to connect tp a network, I AM connected always when home.- I restarted the phone, that seems to have sorted it  (for now)
peterg
Hi Leanne, see earlier comment, It started working again after I restarted the phone, I don't have access to another secure wifi network. As an aside there seems to be problems with the EE mobile network in the Glasgow area according to the MyPlace notifications
8 REPLIES 8
Legend
Legend
Has WiFi-calling worked on this router for you before?
Are you able to use other internet-based functions on this same connection?
peterg
Yes and yes
Leanne_T
Hi @peterg
Have you tried restarting your phone and router and connecting again?
Does WiFi Calling work on any other WiFi network?
Leanne 🙂
peterg
Leanne_T
I see @peterg
Thanks for coming back to me and letting me know.
If you register for updates on the EE Coverage Checker you will be notified of any new updates for the area.
peterg
I do get the MyPlace notifications, but they are a bit vague
Leanne_T
Thanks @peterg
If you would like further information on the area, please give us a call on 150 and the team will get this looked into for you 🙂
peterg
If the system is working, sure. - if
