11-09-2023 12:02 PM
Hi I'm away on holiday and suddenly my phone doesn't work! Its not making calls and there's no data! I can't contact ee as there's just phone numbers? Help
11-09-2023 01:11 PM
A spend cap is an amount that you set for extra charges on your account, @DINOBAMBINO. For example, if you had a £5 limit, the third daily charge would be rejected. Could you check your My EE account to see if one is set up please?
11-09-2023 11:19 AM
I don't know if I used all my data or why I'm not able to make phone calls or use any data. Please help 🙏
11-09-2023 11:44 AM
What? Has someone phoned you from home to tell you that your Home Broadband & landline have stopped working? If so, you should report it to CS.
11-09-2023 12:06 PM
Hi @DINOBAMBINO
Welcome to the community. We'll do our best to help you.
Have you tried restarting your phone and searching manually for another available network? Whereabouts are you? Are you on contract or pay as you go?
11-09-2023 12:23 PM
I'm on contract and currently in cyprus, I've tried restarting my phone and searching for a new network manually but it all seemed to look like they where on auto. Any other advice as it's really stressing me out that I've not been able to resolve this.
11-09-2023 12:30 PM
Thanks @DINOBAMBINO
Do you know if you have an active Spend Cap and whether you're able to change/remove it?
11-09-2023 12:48 PM
No I've got a holiday plan £2.29 per day for eu roaming. So I guess there is no cap as its a daily charge! Is there a way I contact ee with no mobile data?
11-09-2023 01:11 PM
11-09-2023 02:53 PM
I've checked it ended up being the spend cap, thanks so much for this, I've been trying to solve this all day and couldn't have done it without your help!
11-09-2023 03:16 PM
That's great, I was hoping that's all it would be. Enjoy the rest of your holiday, @DINOBAMBINO 🙂
