31-08-2022 10:28 AM
Hello, I’m hoping someone can help…
I’m in the US for work, I was here last month and my phone didn’t work despite having all roaming on and set up so the tech team were able to reset something to make it work. I’m here again and the same thing has happened except this time I can’t reach anyone- the only option for help is to call a mobile which isn’t working from my phone or the hotel. The online ‘start conversation’ button isn’t appearing.
I have small kids at home, not being able to even receive a call is stressful - I’m really hoping someone can help look at what was done last time to help me and do that again?
It took a few hours to solve it on my last trip I didn’t think I’ve have this again- can anyone please help me? I’d be so grateful this has been really stressful
31-08-2022 10:38 AM - edited 31-08-2022 10:39 AM
@VE7 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
31-08-2022 10:33 AM
Hi @VE7
Welcome to the community.
Could you try manually connecting to a different available network please? Which phone do you have?
31-08-2022 10:41 AM
Hi Chris,
Thank you for the quick reply- I’ve tried manually connecting, and also tried the network settings reset as that was suggested last time too but hasn’t helped. When I landed I had 4G just the data wasn’t working but that dropped away and now nothing works except WiFi if I’m somewhere that has it. I have an iPhone 11, software version 15.6.1
31-08-2022 10:47 AM
Oh my goodness that worked in parental settings!! Thank you SO much no one has mentioned that to me before - thank you SO so much for your help @XRaySpeX @Christopher_G
31-08-2022 10:48 AM
31-08-2022 10:49 AM
31-08-2022 10:52 AM
Thank you!
So odd the texts from EE said I was all set up, I’ll make sure to check the online account too in future no one has mentioned that place before - really appreciate the quick replies
