28-12-2023 02:04 PM
I will be travelling across 4 African countries and will need to add LOCAL eSIMs for each one. Can I buy these from EE in the UK, or do I need to source locally in Africa?
28-12-2023 02:31 PM
Your need to source the Sims or eSims directly from each Network Provider.
28-12-2023 03:05 PM
Good luck on your travels. Try the app from the play store "airalo" it uses esims. Used it when I traveled to South Africa.
Easy to setup and you use the local network of the place you visiting.
