05-11-2022 12:32 PM
Constantly having issues with trying to enable things by texting 150. I don't get a response for TRAVEL and have no idea if the pass is on or off. ROAM gives me a generic resposne. Nothing shows in my app dashboard for any of this.
How do I know if it's working or not or do I just wait for a massive bill and then argue?
Currently waiting to board the flight so this should be interesting....
05-11-2022 01:04 PM
You should be able to see it in your online MyEE under Add-ons or Extras.
05-11-2022 01:10 PM
It doesn't show either. I've just spoken to EE and they assure me both are active, but nothing in MyEE and no response from 150 text...
A few months back I got to India and had nothing. Had to bombard 150 with travel stop and travel messages until it eventually worked. They said it was on but I had no connection. I had to stop and start it again... Like windows...
05-11-2022 01:13 PM
What's both? TRAVEL is 1, what's the other?
05-11-2022 01:25 PM
ROAM
05-11-2022 01:38 PM
Ah, that's not a pass giving you a roaming allowance but just a permission to allow you to roam somewhere.
05-11-2022 01:57 PM
That's right yes, but my first stop is Vietnam and the travel data pass doesn't cover there, so I will need to use a roaming option. But. If I can't use 150 then I won't be able to select options.
05-11-2022 02:11 PM - edited 05-11-2022 02:12 PM
As it is not in EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/help-new/roaming-costs/countries/vietnam.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
07-11-2022 04:20 AM
Have just arrived in Australia. My phone will not receive or send texts or phone calls without WiFi.
I have received a message from EE to text Passport to 150. THIS DOES NOT WORK. Very frustrating as you can imagine. No phone, no signal, not contactable unless in a WiFi Zone.
Tried switching phone off, nothing works. Can't call EE as my phone won't allow calls. HELP
07-11-2022 07:56 AM
Thanks for coming here.
If you have a pay monthly account, could you check your roaming status by logging into your My EE account online go to Menu > Account Settings > Parental and Data Controls > Enable Roaming and also Call abroad, do they show as ticked?
Leanne 🙂
