01-02-2022 05:04 PM
Does anyone know if I automatically get 4G max speeds on this plan. I cannot find info anywhere to tell me.
01-02-2022 07:03 PM - edited 01-02-2022 07:09 PM
You will get full 4G+ speeds available on a 5G plan.
I tested a 5G SIM a while back on a know good 4G+ area. was the same as my old 4G+ Max speed SIM, 430mbs DL and 100mbs UL with 5G turned off, not suggesting of course your going to get these speeds though, but yes full Max 4G+ speeds.
01-02-2022 05:35 PM
You'll only get 4G speeds with a 4G phone or with a 5G phone in a 4G area. You'll get 5G speeds with a 5G phone in a 5G area.
01-02-2022 05:41 PM
Thank you. I didn't ask my question very well.
I have a 5G phone what I meant was when receiving a 4g signal do I get max 4G speed.
01-02-2022 06:01 PM
You'll get 4G signal with a 5G phone in a 4G area.
01-02-2022 06:52 PM
@Kicking_up_Dust That’s a very good question. You’ll probably find it’s just up to 60Meg and it doesn’t include the speeds your talking about.
let’s ask
@Christopher_G @Christopher_B @Leanne_T Can any of you shed more light on this ? What is the speed of 4G when you take out a 5G tariff. Max plans had something like unlimited speed and the essential plan had 60Meg.
@XRaySpeX EE used to have 2 different type of 4G plans one that gave you 60Meg ( essential plan ) and the Max plan and that gave you much faster speeds.
01-02-2022 09:09 PM
02-02-2022 07:33 AM
02-02-2022 07:42 AM
You will, but keep in mind that 5G can sometimes be slower than 4G, or even none-operational such as in the Trinity centre in Leeds, full signal of 5G but very slow data speeds, works better on 4G
02-02-2022 08:39 PM - edited 02-02-2022 08:41 PM
@Chris_B that some nice Speeds your getting there Chris.
Glad to see you getting the hang of this 4G and 5G malarkey.
