27-01-2024 05:12 PM
Hi
My contract is unlimited data and roaming abroad, i understand that there is a 50gb fair usage policy which is fine...but how do you check how much data you have used?
The reason i ask is because when i try to check on the app or website..it says don't worry you are unlimited..not helpful when i'm abroad
cheers
27-01-2024 06:20 PM - edited 27-01-2024 06:23 PM
You can't when you're on unlimited! It's up to you to keep an eye on it from your devices. When you hit the FUP you will be notified & any further data usage will be subject to surcharges.
27-01-2024 07:04 PM
Thanks for your reply
How do you check how much data you have used on the IPhone when you have been surfing, streaming and hot spotting etc
cheers
27-01-2024 07:29 PM
Doesn't your phone have any data usage counters by app?
