13-03-2022 09:11 AM
My phone is not enabled for roaming, but my partner's is. I get the bigger data package.
If I were to gift most of my data over to my partner's phone, would I then be able to hotspot from it when we're abroad?
13-03-2022 11:46 AM - edited 13-03-2022 11:46 AM
Hi @Donkey391,
Welcome back to the EE Community. 🙂
Yes, if your partner's plan allows them to use their data allowance in the country you are travelling to, you'll be able to use it via their hotspot.
Hope this helps.
Hi @Donkey391,
Hope this helps.
