06-03-2022 12:31 PM
Classic piece of bad faith product management by EE. They don’t tell you much you’ve used in the hope you will spend more.
06-03-2022 12:53 PM - edited 06-03-2022 12:54 PM
@enrvuk How do you work that out when it’s a set limit per day. It’s up to you if you want to purchase more or not your not forced to. And depending on where you are there could be options to use your tariff allowance.
06-03-2022 07:02 PM - edited 06-03-2022 07:03 PM
First of all, in plenty of situations you need access to data. So you will top up.
Secondly, this information is readily available to EE. They could share if they wanted to. Not sharing the info makes it trickier for us to manage our usage and retain enough of the allotted requirement for critical usage. As a result, we’re more likely to need to pay for more data.
One of the most egregious examples of bad faith Product Management that I’ve seen.
06-03-2022 08:18 PM
@enrvuk : You can see your data usage in your MyEE or you could text AL to 150 whenever you want to know.
06-03-2022 08:26 PM
For your daily allowance?
06-03-2022 08:30 PM
Yes, by subtraction.
What daily allowance have you? Where are you?
06-03-2022 08:37 PM
Where do you say the figure for daily roaming data usage. It’s a general question not related to a particular location.
06-03-2022 08:44 PM
I don't! Roaming data limits are usually monthly except in countries where the data add-ons are per day or week. That's why I'm asking you.
