16-12-2023 12:35 PM
Same issue, I run dual sims Three and EE and both sims display 4G, 4G+ & 5G between 1 and full reception and currently EE has no Internet when Three does. Having just moved one business sim to EE for additional network coverage I'm pretty disappointed...
16-12-2023 02:01 PM
Yea, so turns out the bill hasn't gone out for the first payment 🫢
Hopefully that'll fix it once I'm back where I can access my cards...
16-12-2023 12:53 PM
Can you elaborate on "has no internet"? The 4G, 4G+ & 5G indicators can be taken with a slight pinch of salt, but does VoLTE/4G-calling show?
Are you able to make & receive calls?
16-12-2023 01:43 PM
Hi @19ninety
Have you set your dual SIM settings correctly.
16-12-2023 01:46 PM
Dual-SIM is a good point - make sure that VoLTE & mobile data is enabled on the EE SIM as a process of elimination.
16-12-2023 02:01 PM
