23-09-2022 11:09 AM
I cannot use my data. My Internet only works when I’m connected to Wi-Fi which is super inconvenient. Trying to get through to a human on 150 and have been on hold for 1hr so far.
23-09-2022 11:43 AM
I'm having the same issue... my data always works usually, but today its worked once. Did you get through to anyone on the phones? I'm on hold for 30 mins now...
23-09-2022 11:48 AM
Same issue but only one line have this problem others working fine. I ordered new sim and still not working. I'm using iPhone 13pro max. Now is question is phone or network issue
23-09-2022 12:16 PM
Just hang up and try at a different time, I have never had to wait more than 20 minutes, staff are probably busy with other clients, try first thing in the morning. Just remember it will be the weekend tomorrow, so probably not so many staff working either, but if you are near an EE store, you can go there and they should be able to sort things out for you.
23-09-2022 12:48 PM
I resolved issue! Go Settings - Mobile Data - Network Selections - Turn off automatic! wait until shows other Network - Chose o2 and wait 30 sec then chose ee but not automatic! REstart Your phone and should be fine! Mine working right now!
23-09-2022 01:24 PM
Thanks bud! Working now
03-08-2023 08:12 AM
For me, I transferred to EE from another network and the data was not working. EE support asked me to Open Settings -> General -> VPN & Device Management. In there, there was a profile from my previous network. Once I'd deleted the profile, the data started working instantly. Hope this helps.
03-08-2023 08:15 AM
Thanks for coming here and sharing this @t-ash1891.
Katie
01-09-2023 12:15 AM
This helped thank you 🙏
05-01-2024 03:51 PM
I have the same problem cant access the EE app when selecting mobile data but ok with wifi with my regular broadband. Spoke to a human as AI hangs up and useless. Any ideas thanks.
