22-11-2022 11:40 AM
This message has appeared a few times over the past week or so and my data switched off. When I switch the data back on I get this message again and the data gets switched off. Any idea what's going on? Thanks
22-11-2022 11:47 AM
I've had this happen twice over the last month. Once at St James park at the Rugby, second time at Old Trafford again for the Rugby. It was ok at the Emirates.
It doesn't happen at any other time.
I can only assume it's connected to the number of people in one location, freeing up bandwidth if you're not using it. The reason is that when connected my device worked fine which was unusual as normally it doesn't connect becase of the number of people.
22-11-2022 11:54 AM
Thanks for replying. I haven't been at any events or anywhere particularly busy, just at work or around my home town. Both in different parts of the country so not even from the same mast if it is a mast issue. Still on hold to customer services (25mins) to see if they have an answer.
22-11-2022 02:20 PM
22-11-2022 02:34 PM
Hi. Finally got through to customer support and after going through a few things (checking i didn't have data limit or data warning switched on) they suggested reseting my phone. They guided me through the menus and phone now reset. Fingers crossed that's it solved. It was almost a week between the first time it happened and the next time so only time will tell. Thanks.
22-11-2022 02:39 PM
Thanks for coming back and letting us know @JasonMitchell
Hopefully this is now sorted for you.
23-11-2022 11:48 AM
Turns out this hasn't made any difference. Same problem this morning. After checking the Status on EE website for my area there are works taking place to upgrade the network. Should be OK in 2 days it says. Not ideal.
23-11-2022 11:54 AM
