27-01-2023 09:48 PM
It's is saying that I normally use about 1gb out of my 20gb I have per month.
However this month says I have used 19.35gb out of my 20gb since Jan 18th. How can this possibly be?
28-01-2023 12:00 AM
What is the "it" that is saying this?
What does texting AL to 150 from it fully report verbatim (it is free)?
28-01-2023 10:56 AM
Further to the above, Android & Apple phones have a data counter function which itemises data usage down to each system function & app, and is of great use in situations like this.
You can often set the counting period to match your billing cycle to further assist.
28-01-2023 01:45 PM
Lsim, I think you will find it means you have 19.35gb left out of 20gb, it's quite confusing.
