30-01-2023 03:53 PM
I have recently just switched from three to EE. I was able to download videos from various sites.
Since changing to EE I have access to these sites and can stream them, but it does not let me download. I hot spotted my laptop to see if its just my handset, but my laptop also run into the same problem, only streaming not downloading which leads me to believe it must a be an issue with my network provider?
I have switched my content lock off and it still down not let me download and i have checked all my data settings. I have also switched it to strict restarted my phone and switched it back to 18+ and still does not work.
I have an iphone 12 pro. Any soloutions?
30-01-2023 04:58 PM - edited 30-01-2023 04:59 PM
If you go into Settings > Safari > do you have block pop ups turned on? @Quark262
Also, within Downloads, can you try changing where they are saved to see if this helps?
30-01-2023 04:41 PM
Hi there @Quark262
Thanks for coming here.
Can you download any other files at all?
Do you get an error message when you try and download the videos?
Thanks 🙂
30-01-2023 04:43 PM
so i was using the safari browser, i tried it in google chrome and it works.
How ever safari when i press the download button i get nothing. No message just has 0 action.
30-01-2023 04:53 PM
30-01-2023 04:55 PM
No icloud private relay is turned off
30-01-2023 05:03 PM
that is now working. It was blocking pop ups thank you for your help
30-01-2023 05:05 PM
