08-05-2024 11:26 AM
Maybe somebody might know the answer, i have the 4GEE Router.
I am not too far away from the mast but my BB goes up & down never that good.
When i unplug it for say 5 mins then restart it it usually improves it a bit,so just wondering if these routers are rubbish.
I bought this one from EE a few years ago,i am wondering if i bought a decent make would it make a difference.
08-05-2024 11:53 AM
Hi @jockwav1
Which router do you have.
Have you checked for local issues:
https://ee.co.uk/help/service-status
08-05-2024 12:31 PM
As i said i have the 4GEE router which i bought from EE a couple of years ago.
There are no local issues,it has never been a great D/L speed.
I have been through tests & suggestions here before,but thought buying a good router help.
10-05-2024 07:45 AM
Well,no further forward with this,maybe i just need to shop around now.
14-05-2024 11:14 AM
Something is causing my d/load speeds to be rubbish in my area but i do not know what.
One day i am getting over 100mb d/load next day i am getting 15mb.
So i just do not know what to do here.
14-05-2024 02:02 PM
14-05-2024 02:34 PM
That has already been checked more than once,not showing any.
I don`t know if it`s a problem with this EE router or not.
But my d/l speeds vary a lot,i need to get this sorted out it doing my head in now.
14-05-2024 03:48 PM
Have you reported a problem via the status checker, or just checked for known issues, @jockwav1?
If not, I'd recommend doing that as a first step.
14-05-2024 04:13 PM
So how do i report it then
14-05-2024 04:18 PM
Hi @jockwav1,
After checking the status in your area, tap the Still having problems link, followed by Report a problem.
Hope this helps.
