Ps5
Fluff88
If I buy a ps5 on the 12 month plan do I keep it when the 12 month plan has finished
@Fluff88  Yes.  You’re purchasing it over that time frame .
XboxGamer1987
Problem solver
Problem solver
@Fluff88
Hello.  You sure keep it after the plan is over. I wouldn't want to pay for something and then having to return it after the plan ends.
