26-09-2023 08:45 PM
hi I want to upgrade but keep my same number can I do this?
26-09-2023 08:48 PM
@ward221 log into your account select upgrade and choose the device and tariff that you want and that’s all you need to do, upgrading you will retain your number.
26-09-2023 08:49 PM
@ward221 : That's what an upgrade is by definition; changing your plan while keeping the same no.
