10-09-2022 10:01 PM - edited 10-09-2022 10:03 PM
Hi, EE here. As the UK's best network, we're always making improvements - and now we're making some technical changes that will affect your current plan. So, you'll need to move to a new plan, and possibly a new device, by 15th January 2023
I've just received this text, I've been on an old tmobile payandgo deal that gives you unlimited data and texts for life
You add £10 (which you get to keep)
And you receive unlimited texts and data the following month
Can anyone shed some light in this, is it realy the case that I will no longer benefit from this from January, that would be extremely disappointing after I've been on it for 21 years,
10-09-2022 11:07 PM - edited 10-09-2022 11:16 PM
What has changed now that didn't change previously was that previously EE moved you from a T-M PAYG plan to an EE 3G PAYG plan that retained the free calls & texts for the following month whenever you topped-up (which you get to keep). Now EE are closing all EE 3G plans & allowing you to either move to an ordinary EE PAYG plan, which doesn't have the aforementioned top-up benefit, or leave.
EE can do this as they are not obliged honour any T&C's for ever. All T&C's will contain the condition that the provider may change or remove any terms at any time with at least 30 days notice & if you don't accept them within that period then you may leave.
Incidentally a side effect of this change, as mentioned in the text, is that if you only have a 3G device you might need to go out & buy a 4G or 5G device in its place as the 3G network is being closed in the next year or 2. In fact this proposed closure has triggered this change in plans.
10-09-2022 10:17 PM
Hi @John_yorks
T-Mobile as a brand or services no longer exists. You'll need to move onto an EE PAYG SIM or pay monthly contract.
10-09-2022 10:32 PM - edited 10-09-2022 10:33 PM
I was told that 3 or 4 years ago ,
My presumption is that when ee took over tmobile 6 or 7 years ago, my plan which is unlimited texts and data for LIFE, they're obliged to honour it for life,
What has changed now that didn't apparently change 6 or 7 years ago and again 3 or 4 years ago, when a EE customer service operative explained that I can no longer be on my plan (it didn't happen)
So your argument is flawed
11-09-2022 09:00 AM
Thanks for that explanation, I guess I won't get an equivalent deal on payandgo
(unlimited texts and 2TB) for a £10 top up
11-09-2022 02:57 PM
05-10-2023 07:42 PM - edited 05-10-2023 07:43 PM
So I'm still on the same plan and I've been advised that I can still use it for as long as I want, the big but is
As well as the unlimited texts I'll only be able to connect to a E signal which is as much use as a chocolate fireguard,
Each time I add £10 I get a text that I'll receive unlimited DATA and texts the following month, no mention of unlimited 3G
I've been on this tarrif for 23 years so obviously there was no 4G, at that time,
Isn't it nit picking that because it was originally advertised as unlimited 3G, I can't be moved to the best signal available when 3G shuts down next year and be moved to a 4G sim?
