05-04-2024 03:46 PM
I have just been ported over to EE from a long term FTTP account with BT, while on the phone placing the order i was told the old BT extender/booster discs (black) would work with the new router/hub, this is not the case. I made it clear without i would not sign up, they ensured me they would work, i triple checked this. Since, i have also found they will not work with 6ghz so essentially useless even if they did work.
I have now been trying to contact EE all day, 7 hours on the web chat talking to scripted incompetent people and getting nowhere, what a joke this company is.
Is there anyway to get the new extenders sent out or am i wasting my time?
I will not pay for these as this was the main concern brought to them initially, which clearly was not listened to.
I am within my 14 days cooling off period, but even getting through to cancel is near impossible.
Shocking service!
05-04-2024 03:59 PM
If you have the EE Smart Hub Plus (SH+), model no. SH31B, of Set up your Home Broadband EE Router, you need the EE Smart WiFi Plus , model no. SW30A, of Setting up Smart WiFi to go with it.
That's correct, the black BT Total WiFi discs do not work with the SH+. The white "high st." Whole Home discs would've done.
05-04-2024 08:18 PM
Thanks for your response, I've since got through to EE, as I am on a fiber essentials 500 package they will not send out the WiFi extender/booster.
2 options,
Cancel, or purchase my own extender/booster, ideally 2 would work, one for the garage and one for the 3rd floor of the house.
Any recommendations on what to use, or could be used for a mesh network other than the EE ones?
10-04-2024 01:16 PM
Typo: "Total WiFi" -> "Complete WiFi".
That's correct, the black BT Complete WiFi discs do not work with the SH+. The white "high st." Whole Home discs would've done.
25-04-2024 04:43 PM
Hi DBUK
I'm having exactly the same problem with EE - except this is only one of many issues that have been going on since October - they really are the worst!
I would really appreciate it if you can let me know if and when you find a solution - I'll look to do likewise.
Best of luck
