Speed dropped from 80mb down / 20mb up to 67mb and 15mb down
monitorcurve
I've reset the router, done a factory reset all to no avail, anyone else experience such a speed drop recently? It was around the time when EE rolled out a new router firmware update. 25% drop in upload speed is crazy!
That's the speed it's syncing at in the router page (Was getting 80/20 at the beginning months ago, and also 80/20 when on BT)This is what is on the EE account page:
"Your guaranteed speeds:
65-75 Mbps
Download speed range
17-19 Mbps
Upload speed range"
Nothing new internally has been added or changed.
Using the Smart Hub Plus EE router
10 REPLIES 10
monitorcurve
Spoke to EE on the phone and fobbed off with "because you're getting more than your guaranteed speed there's nothing wrong" despite a 25% drop in upload speed, and they didn't see any issue with that, despite it being 20mbit for multiple years using the BT HomeHub and then moving to the EE Smart Hub for months it was 20mbit, and only recently has it dropped.
Qube engineer (whose only function seems to just be able to turn a router off and on and perform factory resets of said routers) said it was absolutely fine because the guaranteed minimum speed was being hit, even though there's suddenly a 25% drop in upload speed which they claimed was absolutely fine?!?! Next step OpenReach engineer hopefully, as there has been no explanation of a sudden upload speed drop - I am using the sync speed on the route page for these readings.
Having a 25% drop in upload speed for no reason seems bizarre as it has been 20mbit for months and now suddenly syncing at 14mbit and nothing internally has changed.
@monitorcurve   how are you testing WiFi or via ethernet?
Do you still have the BT router, if so have you tried that again to see if it makes a difference?
I assume you are connected via an FTTC service via your phone line - if so is the line quiet - dial 17070 option 2?
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
monitorcurve
I am going by the sync speed shown in the router. Testing via a mix of WiFI and Ethernet, if the sync speed shown on the router admin page is 15mbit, that's all I'm going to get when doing a speed test wired or wireless.
No noise on the line
The old BT router was sent back months ago.
This is the router admin page showing the current sync speed:
monitorcurve
1. Router technical log:
2. Wired speedtest:
3. As you can see from the cabinet screenshot it has hit 80/20mbit, and that is what I should be getting, as I was getting that before.
Anything else I can provide?
@monitorcurve   I think you may missunderstand the BTW DSL check figures - they are an estimate not an absolute guide as to what you may get.
Your sync speeds a little lower than the estimates, and your speed test is as expected for your sync speeds.
You could try connecting your router to the test socket, revealed when taking the front cover off the master socket to see if your speeds are better.
Or wait to see if DLM has any margin to increase your speeds.
Other than that, as your speeds are well above handback speeds there is not much else to be gained at this stage.
monitorcurve
But for more than 2 years with BT the BT homehub was syncing at 80mbit/20mbit, and when switching over to EE-BT merger whatever last November 2023 (now using EE smart hub) it was syncing at 78/19.8~ so give or take the same speed pretty much, and now in the last 2 weeks it has dropped the upload sync speed by 25%, I don't understand this, as nothing internally has changed.
Not possible to check the test socket at the moment, as the connection is being used, but will try and test that directly later on.
@monitorcurve  do you still have a phone? If so is the line quiet, dial 17070 opinion 2?
Lines can deteriate over time, any noise will reduce sync speeds.
It may also be that the BT Router has a more efficient modem than the new EE one - which one is it by the way?
monitorcurve
Just did a quiet line check, and no noise can be heard on the line.
The new EE router is the Smart Hub 3 (SH31b)
