Smart WiFi Plus
Matty2003
Can I connect my EE smart WiFi plus to my ee smart hub plus with a Ethernet cable wired like simply having a another router if that’s possible to get a full maximum speed connection?
@Matty2003 : Yes, it shows you in its Set-up Guide.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
Yeah I know but what I mean is simply keeping it connected wired to the router without disconnecting the Ethernet cable and using it wirelessly but keeping it plug in on both ends the smart WiFi and smart hub plus both wired will that boost insanely my WiFi upstairs as I have WiFi socket’s Ethernet ports that will transfer the signal to my router
No, it might slow it down if you are on the 1.6 Gig FF package as the Ethernet ports on the SH+ are only 1 Gig.
Is it possible the more ee smart WiFi pluses I get the more coverage I am getting for the best WiFi experience?
