12-10-2023 09:28 AM
My landline phone is not working I can’t make or receive calls
12-10-2023 11:25 AM
Hi @betty29
Please see our How Can I Repair Faults On My Home Phone Line? | Help | EE for help and steps to try for the landline problem you are having.
Leanne 🙂
12-10-2023 11:38 AM
Is your BB working OK, albeit slowly?
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Does the phone work from there?
