Meeross garage door opener
Tx1oss
I have a garage door opener that shows the wifi connection as 25%, I have 4 BT disc as a mesh system the disc connected to the router is the furthest away from the Meeross device and yet this is the disc that it connect to, i.e there are 2 disc closer to the meeross but it doesn't connect to them, 1 of the disc that is showing as a very good signal is 12" away, any ideas please.
@Tx1oss  You could try switching off the disk to see if it connects to a closer disk but unfortunately you can not force it to stay on that disk when you reboot the turned off disk
I’ve got an Apple TV that connects to my router when a disk is closer to it and I’ve another Apple TV that’s in the same room as the router and it connects to the disk that’s upstairs.
Tx1oss
I have tried that today, when you switch off the disc closest to the router i.e connected by cable, you lose all wifi on the disc.
Worth a try though.
Thx
