09-05-2024 12:45 PM
Just moved to fibre broadband and landline, phone not ringing despite ringing at caller's end. Can still make calls, but not receive.
09-05-2024 01:15 PM
@Gilbey1 have you moved your phone to connect via the router?
Have you spoken to the Broadband Care Team about this? There is no account access on here.
09-05-2024 01:19 PM
Yes, plugged into green phone port. Will contact care team. Thanks.
09-05-2024 01:38 PM
@Gilbey1 If you still have an DSL dangly filter you could try that between the phone and router - not sure why, but it has been know to help.
09-05-2024 01:42 PM
Thanks, I'm still using "dangly thing" as it's the only thing that has correct port for grey cable.
09-05-2024 01:44 PM
? What phone are you using and does it not have a standard BT phone connector?
09-05-2024 04:38 PM
Thanks for your help. EE have found fault with network, engineer coming out next week
09-05-2024 05:08 PM
Let us know how that goes.
