EE Smart WiFi Device
iammbuk
Skilled Contributor
Skilled Contributor
Hello
I ordered Fibre broadband last week and just waiting on the install, what I wanted to check was once the service is installed and running can you add EE Smart WiFi devices to your p[lan as I forgot to do this when I ordered it, can they be added at anytime or only when the contract renews?
Mustrum
@iammbuk   simple answer - yes. Just give the care team a call - you may have to mention if you are on New EE.
Mustrum
iammbuk
Skilled Contributor
Skilled Contributor
thanks
