06-05-2024 05:34 PM
Hello.
Following on from mine and a good few others posts regarding issues with connectivity regarding the smart hub plus. Please can somebody tell me what the optimal settings are on the hub to get the best performance?
I have no idea which channel should be used. It is just at the factory setting. I will give this one more go before cancelling EE
thanks
06-05-2024 06:09 PM
What do you mean by optimal. What problems do you have now.
06-05-2024 06:43 PM
I keep getting dropped signal, iPhone and iPad says no internet connection for a good few minutes at a time. Then it will work fine for a few hours then play up again for a while. It must be switching channels maybe? Ethernet is working perfectly, getting 900mbs no problem. It is just WiFi
