06-03-2024 01:18 PM
Hey EE community,
We just received an EE Smart Hub (2023).We're looking to integrate it fully into our smart home setup with around 100 connected devices. The issue is the new hub's password requires letters and numbers, unlike the old one, which was just numbers. Any hacks to stick with numbers only for the SSID password?
07-03-2024 05:55 PM
Hi @oliversharp and thanks for the post.
The minimum password length is 8 characters. 8 numbers or longer will work (even 8 zeroes). If you see a warning pop up just click Accept and the changes will be applied.
Hope that helps.
Cheers
David
