04-07-2022 11:50 AM
I have connected a Samsung memory device to my smart router. The smart router manager shows status as 'connected' but I am unable to work out how to access the files on the device. Any help or advice would be greatly appreciated. Kind regards, bryan R
04-07-2022 01:34 PM
Hi @bryanR.
Welcome to the community.
Have you been able to access files on any other connected devices?
Jon
04-07-2022 01:38 PM - last edited on 04-07-2022 04:51 PM by Leanne_T
**Edited for @XRaySpeX to include the image below***
If Win, have you enabled SMB 1.0 File Sharing Support in Program Features?
In File Mgr click on Networks / Computer / SmartRouter to see the USB attached drive. See below but pretend "BrightBox2" is "SmartRouter":
tba
I expect iMacs are similar.
04-07-2022 02:23 PM
Hi Jon,
Thank you for your thoughts. I've never connected anything else to the USB port but, I am able to access files on the devices connected on Ethernet and Wireless
Bryan
04-07-2022 04:09 PM
Hi @bryanR
It's likely the port doesn't deliver enough power for the HDD to run. The Samsung M3 is not a SSD drive.
05-07-2022 02:13 PM
Thank you Leanne_T,
one small surprise, mine is showing BT HomeHub6DX😀 but, like your image, does not show any files.
Are you able to access files through this link on your system?
Many thanks
bryanR
05-07-2022 02:25 PM
FYI: It's my image. I had a bit of trouble uploading it & @Leanne_T helped me with it.
05-07-2022 02:36 PM
05-07-2022 02:47 PM
Thanks @XRaySpeX, are you able to help with the question about seeing or accessing the files?
thanks
bryanR
05-07-2022 03:22 PM
Yes, just click on the router's Computer icon and you'll see the drive and its files below it. You might be asked for a password.
