04-01-2023 10:04 PM
Hello,
I'm trying to replace my old Asus router with a new TP-Link due to connection drop outs and range problems.
I have a TP-Link Archer AX23 that I bought new connected up to the existing openreach fibre modem.
Using the following settings the connection to the WAN won't connect.
I optained the username and password details by calling EE due to nolonger having the admin login for the old router and never having an EE router.
Does anyone have any experience with this setup that could shine some light on this issue?
Thanks for reading.
Jack
04-01-2023 10:11 PM - edited 04-01-2023 10:12 PM
@VortexHD1 wrote:
- Username: (hidden)orangehome.co.uk@fp
It's '@fs' not '@fp". You must've misheard. There's a '.' after '(hidden)'.
04-01-2023 10:16 PM
You also don't need the VLAN setting on the router, the modem should handle that.
06-01-2023 10:26 PM
Thanks both of you, worked straight away with the 2 changes. 🙂
06-01-2023 11:13 PM
