28-07-2023 08:31 PM
After moving house a couple of months ago, things have calmed down enough for me to consider switching out the supplied (white) EE Smart Router. I used a fantastic ASUS RT-AX82U at my old place which I wanted to tag in, but spent the last half a day trying to get it to work (to no avail). In the process of trying I've learnt a few things (posted here so people can double-check if wanting):
As such, my current thought process is that I can buy a half-decent modem, and just switch that out with the EE Smart Router (and then plug the ASUS into that). In this case, I'd like to ask a few questions:
Thanks so much for any help anyone is willing to give!
28-07-2023 10:38 PM - edited 28-07-2023 10:40 PM
Full Fibre (FTTP) has the ONT; all other Fibre (FTTC) doesn't but comes down a landline.
Answers are:
28-07-2023 10:55 PM
Thank you for your response.
Given I already have the ASUS RT-AX82U, I'm looking at a slightly more budget fix than buying a whole new router (with an integrated modem). As such I'll have more of a look at (standalone modem) VDSL2 alternatives- are there any brands (or models) you'd recommend?
28-07-2023 11:09 PM
Hey @DG_070 your plan sounds sound, providing you are on VDSL, and not on G Fast - also delivered over your phone line with speeds above 80Mbps?
Some people like to plug/install and forget, others like the idea of being able to monitor, or at least view modem stats, not least to ensure you are getting the most from your line. The Openreach modems are locked as standard, so don't help if you want that info, but there are other options that may help, the TD-W9970 router can be used in modem only mode, or even the sister PN Hub 2 to your EE Smart Router can work in bridge mode. Or indeed the DSL-AC88U, again assuming you are not on G Fast.
Were it me, but you are not! What is important to you?
28-07-2023 11:14 PM
Good point about G.Fast! In which case you will need a G.Fast modem.
Which EE BB product do you have? If it has "Max" in its name it's G.Fast.
28-07-2023 11:45 PM
Thank you both for your responses.
I had no idea what I was on until today, but apparently it's G.Fast (as I'm on the Fibre Max 100 package). I guess that rules out the modems I was previously looking at, so great spot!
Does this also rule out all of the products mentioned above? If so, are there any further recommendations you can make?
In terms of what's important to me... if I'm being honest, plug and play was the original aim. But monitoring/optimising sounds like something that could be very interesting, so depending on the price hike that would require I wouldn't mind looking into it!
28-07-2023 11:57 PM
A bit late now, but using the ASUSin AP mode could be a simple solution. But if you want/need it in router mode G FAST modems are harder to come by..
Tomorrow may come with new ideas.!!
29-07-2023 01:46 AM - edited 29-07-2023 01:49 AM
The ASUS DSL-AC88U does support G.Fast. They are hard to find but others may suggest some others or G.Fast modems.
You could always continue using the white EE Smart Router, which is 1 of the rare ADSL/VDSL2/G.Fast modem routers.
29-07-2023 02:01 PM
After the suggestion about using the ASUS in AP mode, I think I've been quite ignorant of networking in general- my belief was that if I wanted to use my router it had to be through bridge mode, but that apparently is not the case. In which case, could I check a couple of things:
29-07-2023 02:54 PM
@DG_070 I don't believe the mesh systems are compatible, manufacturers like to do their own thing.
I guess you will have to work that one out and will depend on why you want to use the ASUS and will it do those things in AP mode.
No.t sure where you have the PiHole , but if it is working now, no reason it should not
