Will my thump print allow access to all my apps if I put my upgraded SIM card
Traciedoll
I’ve been sent an upgraded sim, it worries me if I insert it into my phone will my thumb print allow access to all apps eg online banking, there’s no way I can remember my passwords for all apps?
A upgraded SIM should not affect the operation of your phone in any way.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
Northerner
Hi @Traciedoll
Your finger print is encrypted locally on your device. If you have a new device then yes you'll need to set up those apps again with your passwords and then authorise the finger print you have entered during the set up process.
If you are just replacing your SIM then nothing will be different as @XRaySpeX has said.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
EE standard opening hours are 8am to 10.30pm every day.
