23-01-2024 11:11 AM
When I call voicemail or 150 the key pad on my iPhone 14 isn't being recognised by the system - so I'm unable to choose any options. Is there a fix for this? I've tried restarting my phone.
23-01-2024 12:36 PM
Are you using a screen protector. Does this issue happen with other apps.
23-01-2024 01:10 PM
It's fixed now. The problem seems to be that there are two numbers to dial into voicemail. One of the numbers was causing the problem. When I dialled in using 22204 the keypad worked fine.
