21-01-2023 06:23 PM
I have a Samsung s21 FE
I am unable to use my Internet. WiFi everything works.
when I try to use 4g/5g anything that's not WiFi the Internet doesn't load.
I am still able to message on what's app
but not access the Internet
I have moblie data on. I have loads of Internet left. I have roaming on. I've turned it on n off again. done all the upgrades.
21-01-2023 06:59 PM
Hi @kelsey008
If WhatsApp works them your device is connecting to data.
Try a different browser. Try the the BBC website.
21-01-2023 07:28 PM
hello
I just tryed it
doesn't load. I have Internet coz I can use WhatsApp
just can't load any websites tryed Google and Samsung Internet- both same doesn't load
thank you for your reply! xx
21-01-2023 08:39 PM
Hi @kelsey008
If you're content lock is active (look on the EE app) then you cannot get on certain 18+ sites.
Try going into settings apps - three dots and reset app preferences
WhatsApp uses data so if you can use WhatsApp on 4/5G then everything else should work.
21-01-2023 08:55 PM
it's any website not 18+ any site bbc or anything, apps work just not any other thing!
I looked in settings all seems OK.
I did a area check and it has 5g.
thank you again for an answer!
22-01-2023 08:24 AM
22-01-2023 08:45 AM
everywhere
22-01-2023 08:48 AM
Hi @kelsey008,
What happens when you try to load a webpage? Do you see a particular error message?
22-01-2023 08:51 AM
nope just doesn't load.
22-01-2023 08:57 AM
Hi @kelsey008,
Please get in touch with Technical Support so a member of the team can take a look at this issue for you.
They'll be happy to help. 🙂
