10-07-2023 11:44 AM
Good morning,
I have a Google Pixel and I have an annoying issue where if people leave me a voicemail it doesn't show up on my phone as a notification, if I restart my phone then it appears as it should, has anyone else had this issue and managed to fix it?
I have checked and the voicemail notifications are set to be on and ignore Do Not Disturb etc ... short of restarting my phone every night or calling voicemail once a day I have no way of knowing that I've got a new voicemail.
Thanks,
Dave
10-07-2023 02:05 PM
Hi @DaveD1985
Welcome to the community.
Could you try turning those notification options off, then back on again? Hopefully that triggers a fix.
12-07-2023 08:03 AM
Hi Chris,
Thanks for your response, unfortunately it doesn't appear that you can turn the notifications off on Google Pixel, there's a slider for it, but when you press it nothing happens it stays locked on "ON".
I've tried it at carrier level turning it off and then back on again, but yesterday I got a voicemail yesterday which didn't show until I restarted my phone today.
Not sure what else to try tbh.
Dave
12-07-2023 09:34 AM
Do you get the option for notifications when you call your voicemail, @DaveD1985?
12-07-2023 12:50 PM
I've been through all the option in voicemail when I call the number, no options relating to notifications. Only option to turn it on / off I've found is to text VM ON or VM OFF to 150.
12-07-2023 01:26 PM
OK, thanks @DaveD1985
I suggest speaking to our Mobile Care team so they can check everything from our side for you.
