09-01-2022 09:51 PM
Any help is welcome, caller ID not showing on my phone?
10-01-2022 08:15 AM
Hi @Trevor631
Welcome to the community.
Try checking these settings:
Open your 'Phone' dialler (as if you're going to dial a new number).
Tap More (top right corner)
Tap Settings
Tap Supplementary services
Enable Show Caller ID.
Let me know if this works.
10-01-2022 10:52 AM
I have already tried this method and it does not work, thanks anyway 😉👍
10-01-2022 11:20 AM
OK, thanks @Trevor631
Have you spoken to our Mobile Care team yet? They'll be able to make sure everything is set up for Caller ID from our side.
10-01-2022 11:24 AM
Hi Chris, I spoke to them on Sat and they said it would be sorted out in 24 hrs but it is still the same, no caller ID just says private number 😒👍
10-01-2022 11:26 AM
It could be that the number is being withheld from the other side, @Trevor631.
Could you do a test from some different phones where you know the number isn't being withheld, just as a test?
