10-04-2024 09:36 PM
Hi. Recently got an S9 5G tablet, all is good except the phone is not working. SMS is all OK,as is data.
Rebooted, and re-inserted SIM. Any help would be appreciated. Thanks
11-04-2024 08:19 AM
Hi @dharr55522
Welcome to the community.
Are you able to try the SIM in another device to see if you're able to make calls from it?
11-04-2024 09:04 AM
Thanks for the reply. The SIM worked well in the prev S8, and I removed it to test in that again. No problems. The S9 is just not playing.
11-04-2024 10:26 AM
Do you get any error messages, @dharr55522?
11-04-2024 11:04 AM
No - nothing at all. All that happens is about 2 secs after dialling, it makes the disconnection sound and up jumps the 'call ended' message, no matter what number tried, even the EE 150 line.
11-04-2024 11:27 AM
Could you make sure that call barring is switched off, @dharr55522?
11-04-2024 12:41 PM
Good point -I'll have a look. Thanks.
11-04-2024 08:28 PM
Hi - Thanks for that- but on getting into it I found call barring is off for all except 'international calls from home' . But, interestingly, it asks for a call barring password upon any attempt to change anything, then comes up with a 'failed to read data' message....
12-04-2024 07:45 AM
I'm stumped, @dharr55522
It may be worth giving our technical support team a call, to see if they can help with this.
12-04-2024 07:30 PM
