13-12-2020 03:08 PM
Hi, I have recently upgraded to oppo A72 but can not get it to work with my ring doorbell. Anyone else had this issue? I can hear the visitor but I cant talk back through the device, the microphone is on but just hear a buzzing sound. Doorbell works fine with other phones.
13-12-2020 03:10 PM
@Karen77stock You might want to contact ring about this as it’s their app your using You’ll probably find a report an issue within the ring app.
13-12-2020 03:15 PM
14-12-2020 08:58 AM
Thanks for coming back to us @Karen77stock.
I would recommend following the advice provided and speaking with our technical care team.
Please let us know the outcome,
Katie 🙂
15-12-2020 06:55 AM
15-12-2020 08:23 AM
15-12-2020 02:27 PM
@Karen77stock But they’re supposed to configure it for every version android that their App could be put on. It’s their app that’s not working correctly on your device.
You need to bring this up on THIS forum.
16-04-2022 07:49 AM
Hello Did you get this sorted? I would like to get a ring door bell and have the same phone as you.
Thank you
