17-03-2022 09:27 AM
I upgraded to OPPO A94 in December and it has been a major issue since day one.
I was almost going to cancel the upgrade within the cooling off period but the only issue at that time was the WiFi constantly turning itself on at random times.
Since then the SD Card is no longer recognisable on the phone unless I keep restarting the phone and the phone settings has no "Lock Screen Magazine" - which this phone should have.
Anyone else have issues with OPPO A94 and how can I get rid of this phone?
17-03-2022 09:51 AM
Have you tried replacing the memory card as they don't last forever.
I would also back up and factory reset, then check for updates.
17-03-2022 10:04 AM
The SD Card was working perfectly, no issues whatsoever, as recently as December in my Huawei (previous phone).
Also the OS is up to date with regards to the other issues.
Still have no resolution.
17-03-2022 11:42 AM - edited 17-03-2022 11:43 AM
Hi @borontrichlorid,
Does your SD card still work in your old phone?
17-03-2022 11:51 AM
Hi and thanks.
Yes the SD card works perfectly and is detected in both my old Huawei P30 and even older Huawei P8 Lite (the latter of which is 4 years old)
17-03-2022 11:59 AM
Please get in touch with Customer Care so our Technical Support Team can run through some diagnostics with you.
They'll be happy to help. 🙂
17-03-2022 12:13 PM
I have been talking to them all morning.
My options are limited to mend+lend (I either get a replacement phone if the phone is truly up the wazoo but I don't want an OPPO ever again or I get my actual phone back if they determine it's fine) or claiming on insurance which presumably leaves me again with a replacement OPPO.
So either way I am stuck with OPPO.
Don't feel helped at all.
17-03-2022 12:31 PM
That's right, any warranty or insurance replacement would be like for like. I'm afraid it isn't possible to receive a different phone.
