New Samsung S22
Alyjo7
I have just received my new Samsung 22. through the post . It did not come with a SIM card . I have checked to see if there is a SIM card already in the new phone but it just has a little Sim tray/ holder that says Sim 1 on one side and Sim 2 on the other side .
My old phone is a Sony so my old Sim won’t fit into new phone .
So should I have received a new SIM card for the new phone in the post ?
If you did an upgrade you might not get a new SIM. Your old SIM could suffice if it fits.
Otherwise, Take phone & old SIM into an EE shop with Photo ID & they'll transfer number, any SIM contacts & credit if applicable to a replacement SIM of correct size for free or order a replacement SIM online at Order a replacement SIM for £1.50 or phone CS for one. It will come as a Combi-SIM with all 3 sizes as push-outs.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
nothingaboutme0
Expert Contributor
Expert Contributor
You likely need a new SIM card for your Samsung S22. Your old Sony SIM won't fit as sizes differ. Contact EE to get a new SIM and transfer your service. Your new phone supports dual SIMs, so you can use two lines if needed.
Many thanks indeed for that advice . I will go into my local EE shop and get it sorted .
