01-11-2022 02:47 PM
Can somebody tell me if i have only 1 device and use the same browser all the time why it has alot of diffrent browsers where i have logged in from
01-11-2022 04:47 PM
Hi @David306
Thanks for coming here.
Is this a certain website or app showing different browsers?
What device are you using?
09-11-2022 01:33 PM
Hi @David306,
Thanks for the post. Sorry for any confusion caused.
The information, available via your profile page, under the heading, 'Browser used for Last Visit' can get a little confusing, especially when it seems that it's reporting multiple different browsers, some of which you may have never used.
The reason for this is that your browser will send its 'User agent' to every website you visit. The 'User agent' is a string of text identifying your browser and operating system to the web server.
Please take a look at this link, What Is a Browser’s User Agent? as that will explain, in more depth, what a user agent is and why it seems to list browsers that you have not used.
Cheers
Sean
