08-01-2024 12:21 PM - edited 08-01-2024 12:40 PM
I have purchased a new EE SIM card and put it in my Samsung A40. I can receive calls, and send texts use mobile data but I cannot make ANY outgoing calls. Not to ANYone, nor 150 nor voicemail. The Sim card works in other phones, but not this one.
What can cause this? I would have assumed a setting on my phone but all I can see online I have tried doesn't seem to work.
I have tried setting a network manually (EE), I have made sure I have no blocking outgoing calls set
10-01-2024 08:15 AM
I used the Samsung Switch app to back up my phone to my PC then did a factory reset on the phone. Restored my data and now I can make calls. Thank you everyone for your suggestions.
08-01-2024 02:43 PM
Hi @SusanB2023
Welcome to the community.
Are you in the UK at the moment? If so, could you try all of the steps on this Samsung help page please?
08-01-2024 02:49 PM
Hi Christopher,
I followed all these steps before posting this message. The fact that I can send texts and receive calls I think negates some of these tests anyway. However, I did try them all to no avail.
Yes, I am in the UK, I am not roaming.
08-01-2024 02:54 PM
OK, thanks @SusanB2023
Yeah, it's a really strange one, since the SIM works in another phone. It could be worth backing up the phone and restoring it to factory settings.
How do I backup and restore data on my Galaxy device? >
08-01-2024 03:01 PM
Thanks. I have been trying to do this, but I can't get my PC to recognize the device to back up my phone to it, using Smart Switch.
I will see if I can do any of the other options. Using Samsung Cloud Backup doesn;t work either as it wont upload anything.
08-01-2024 03:26 PM
If your SIM works in another phone, that negates a SIM or account issue. Is your new SIM a pay-monthly one, or PAYG?
Does 4G & VoLTE display on-screen when you try making a call? What happens when you dial?
08-01-2024 04:38 PM
It is a Pay Monthly SIM.
And the phone displays 4g and VoLTE. I have tried disabling VoLTE made no difference, so enabled it again.
10-01-2024 08:15 AM
10-01-2024 08:18 AM - edited 10-01-2024 08:19 AM
Thanks for coming back and letting us know @SusanB2023
Glad to hear this is now sorted for you.
Leanne 🙂
