16-05-2024 08:59 PM
I am on a pay monthly contract that includes roam abroad. The data will turn on but it won’t actually work despite having bars. I called ee multiple times to make sure everything was sorted before coming abroad but it isn’t working. I then called ee from another persons phone to try and get it fixed and they incurred an extremely large charge. I have tried toggling airplane mode, turned my phone off and on multiple times, and any other advice on here. I have no way of contacting ee through livechat or anything so I’m rather stranded. Is there any advice anyone can give me?
16-05-2024 09:05 PM
If you have activated roaming then check your phone setting to check you have roaming activated.
Where are you and what device do you have.
16-05-2024 09:09 PM
Roaming is activated in my phone settings.
I have an iPhone 12 and am in Mexico.
When I message 150 they reply saying that they are unable to determine which roaming product I currently have.
I have received the charge for the roaming abroad pass and when on the phone with customer service, they say it was activated.
16-05-2024 09:11 PM
@Username1239495 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
16-05-2024 09:24 PM
I had called right before going abroad to activate it. Is there a way to activate it or check it is once abroad without calling, as the charges are so big?
I tried selecting a network but still no luck.
I’ve rebooted my phone a few times.
16-05-2024 09:32 PM
What is the "it" that you activated? From your OP it sounds like the Roam Abroad Pass. Having a roaming billing add-on doesn't of itself activate roaming on your a/c.
I told you how to call CS using Skype & it should be free.
16-05-2024 10:56 PM
You can easily prove whether roaming is activated, by testing your phone's local network connection. Are you able to make/receive calls or send/receive text messages?
The majority of the time, a local network connection being displayed, is good evidence. But if one coverage-reliant service isn't working, it's not always conclusive. Testing it, is. As already mentioned, a billing add-on does not automatically enable the roaming facility that unlocks access to foreign networks.
17-05-2024 03:20 PM
I have been receiving text messages from 150 and send responses, but I am unable to make calls.
I received a text from ee that detailed what is in my contract and it stated that my inclusive extra was the roam abroad pass.
But, a previous text from ee said that they were unable to determine which roaming product I currently have.
17-05-2024 03:28 PM
If you can send & receive texts, you have a network connection and are thus roaming.
An inability to make outbound calls would tend to suggest either a local network issue (possibly VoLTE-related), or a spend-cap problem.
