Data & Texts abroad in Europe
CF110
Hello everyone,
im currently away in an EU country and I have data roaming in the EU activated. I was able to text, and use data but now it’s not letting me even though it’s turned on and says “£2.15 a day data roaming in use”.
As it wasn’t working I even just purchased a £10/month package and it’s still not working. What’s going on?
Mark-Loat
Hello @CF110 , it's @Mark-Loat here,
What I suggest is confirming what country you are staying in,
If that doesn't work with the issue, please let me know and I'll try my best to help you
James_B
Do you have a spend cap on your account, @CF110?
Legend
Legend
In what way is your roaming service not working? Are you not able to get a local network connection? Or is it a problem with making calls, sending texts or using mobile data while a local network is shown as available?
What is the £10 add-on that you've got? If coverage is shown but you have problems using any function that would incur charges, then a spend cap is the first check to make.
If the symptoms are something else, then other advice applies.
There is no such thing as "data roaming in the EU activated". I presume you mean you have enabled roaming in general by texting ROAMEU to 150.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
