01-02-2024 01:30 PM
It may well have been yesterday as well but no one called me and I didn’t call out. I also chose BT sports as the add on which I can’t set up as it says it is not working. When I go on to look at my plans it shows my daughters (under my name) but fails when I select my phone. I can’t call EE as I have no other phone to use. Any ideas? I have turned it off and on again (twice)
01-02-2024 02:47 PM
A change of plan is exactly that - just a change of payment plan. Does your phone show coverage of EE's mobile network?
01-02-2024 02:58 PM
Ah no. It shows 4g but it is not letting me access any webpages etc.
01-02-2024 04:22 PM
Hi @emma829
If you pop your postcode into our coverage checker and hit 'check status', does it say if there are any maintenance works in your area.
01-02-2024 05:48 PM
01-02-2024 06:13 PM
Does your phone show VoLTE (Android) or 4G-calling (Apple) next to the coverage indicators?
If you swap SIMs between your phone and your daughter's phone, does the problem follow your SIM or remain with the phone?
