17-10-2022 03:36 PM
17-10-2022 04:18 PM - edited 17-10-2022 04:19 PM
@Anthony541 , what phone are you intending getting? This will be up to you.
You can back up your data, and then if the same make, it should be easy to transfer all data.
I have done this with Apple, it will ask you when you set up a new phone, or you can start from scratch.
I assume it should be the same for Android.
It should not matter where you get the phone from, as long as you have a backup it is very easy.
17-10-2022 04:24 PM
17-10-2022 04:31 PM
@Anthony541 : No data is transferred by EE; just your new plan is on the SIM. It's for you to transfer your data, aided by apps which your phone's manufacturer will hopefully supply.
17-10-2022 04:31 PM
@Anthony541 were you told this in store or by ringing customer service?
How old is the phone and how long have you had the SIM card?
It actually does not matter what phone you have so long as it works, but if this is 3G, then unless you are happy to use 2G, then you could be ok for calls and text, but otherwise, it is correct you would need to change to a phone that at least has 4G as 3G is being switched off in 2023.
I would say, that it is difficult to know what data you are needing to transfer, or is it apps you want to transfer?
I went through this with Nokia Lumia, which was taken over by Microsoft years ago and many apps stopped working.
12-08-2023 10:57 AM
Is that an ee official policy or is that what you think should happen? Will the shop help transfer my private data to another phone
12-08-2023 11:32 AM
Hi @Darkshahh
When you upgrade the data would need to be transferred from the old phone.
Which model phone are you using at the moment, and which model are you moving to?
Leanne 🙂
