05-05-2024 09:27 AM
Hi guys,
I’m currently in Turkey but I haven’t activated my roaming prior to leaving the UK.
To set up Roaming I need to text 150 but my messages aren’t going through.
any other way around this ?
I have access to wifi
05-05-2024 09:32 AM
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
05-05-2024 11:37 AM
You need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
