16-12-2023 08:10 PM
I am about to travel abroad and my contract runs out two months into my trip. Will I be able to switch to a sim only contract whilst I’m out there or will i need someone to activate my sim in the UK and send it over? Also how long does the roaming pass take to activate?
16-12-2023 09:57 PM - edited 16-12-2023 09:59 PM
@Jackds The roaming pass is automatically enabled once you purchase it. Buy it the day before you go. Your contract only reaches its minimum term whilst you’re away, it will continue on a 30 day rolling contract once you reach the minimum term. Do not upgrade while you’re out of the UK or you could end up with no service. When you upgrade there are account changes and these are linked to your SIM card but when on a roaming network the update process doesn’t always find your sim because of you being on a roaming network so you could end up with no signal. Not to mention all add ons are removed when you upgrade so this could affect the roaming pass. Ie it’ll probably be removed.
Don’t forget to text ROAM to 150 to make sure roaming is enable on your account as purchasing add ons doesn’t enable roaming. You can do this now.
16-12-2023 10:34 PM
Thank you Chris. Just to query your last message, if I switch to sim only whilst abroad there is still the potential it could work or is that a definite no? Also is it not possible just to stop paying for the phone after the contract expires and just start paying for my usage? I only ask as I’d like to keep my number and stay with EE when I’m back but it’s sounding like I should just get a payg sim out there.
17-12-2023 03:09 AM
Switching between a phone plan & SIM-only plan is just a price-plan change and should be perfectly safe to do anywhere in the world.
It's just an account change and should have no impact on your SIM whatsoever.
