Roaming
tolgaamutluu
Hello everyone, I just arrived Czech Republic 10 mins ago. When i check my roaming from app it is saying you can enjoy your data, mins and texts but unfortunately i can’t. What is problem in this situation? I can’t even call ee support
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. There is no option on the mobile app to check the roaming facility, only your billing status.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
