18-03-2024 04:58 PM
18-03-2024 05:17 PM
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
18-03-2024 10:17 AM
No service
18-03-2024 04:59 PM
Roaming
18-03-2024 05:17 PM
